June 14, 2023 at 10:08 am
Hi tipupanchal,
Are you facing this issue with the specific model, or is it happening with other models too? Sometimes it’s related to the system’s screen resolution too, so kindly use the compatible screen resolution with the Ansys product. Have you also checked the other options available in the DPI setting too? Always try to close the ansys module as you change the DPI setting then open it.
I have attached two forum threads below that might be helpful to you.
Sizing on Ansys Workbench 19.2
Ansys/Workbench/DesignModeler Display issues
Sampat
