Aniket
How many bodies do you have, can you use bonded contacts instead of using shared topology? also, are there any interferences in the model, if you have them shared topo operation would first remove the interfernces and then share topo. Also, which share topo operation are you using ins SpaceClaim? the one under properties of component or under Workbench ribbon tab?
-Aniket
