Mario Liebermann
Hi Sampat,
thank you verry much for your answer.
It is a 3D model, I just thought it is easier to explain with the top down view.
My process differs slightly from the tutorial.
I started with a scetch on the Y-Z-plane (x=0) and snapped the rectangle the intersections of the other planes. Then I used the pull tool with the up to funktion and clicked on the other Y-Z-plane in x direction. As further option I choose to not merge the body's.
My next step is to try the process following the tutorial step by step.
I will comment if that was the solution!
