That's the one. It removes the contour smoothing, and in this case suggests you may want to review the mesh resolution. You can also plot the mesh on the surfaces, but I think you've set too high a maximum cell size in this case.
Combine that with the resistance coefficients (they're high but I've seen worse) and I can see why the results may drift a little.
