Sarojini Mahajan
Hello, I was reading this thread to get an answer related to creating structures in the script editor. I want to create and rotate a gold nanorod along the y-axis by 90 degrees. Here is the script which I wrote:
radius_ends = 20e-9;
z_span = 92e-9;
radius = 20e-9;
length_circle= z_span-2*radius_ends;
addstructuregroup;
set("name","Rod");
addcircle;
addtogroup("Rod");
set("x",0);
set("y",0);
set("z",z_span/2+gapwithglass);
set("z span",z_span-2*radius_ends);
set("material", "Au (Gold) - Johnson and Christy");
set("radius",radius);
addsphere;
addtogroup("Rod");
set("x",0);
set("y",0);
set("z",length_circle+(z_span-2*radius_ends)/2);
set("make ellipsoid",1);
set("radius 3",radius_ends);
addsphere;
addtogroup("Rod");
set("x",0);
set("y",0);
set("z",-(z_span-2*radius_ends)/2+length_circle);
select("Rod")
set("rotation 1","y",90);
I can create a structure but rotation doesn't work for me. Can you help with the script?
