Vicent Marwa
Am using Ansys 2021R2 I want to predict time taken to cool a container with three layers, Outer layer Galvanized sheet of 1.5m, between layer polyurethane foam of 60mm and inner layer aluminum of 1mm. The container is surrounded by evaporator using compression vapour system. If the surrounding is 32 degree and inner is 2degree.
In the above figure you can see looking as on layer but in the reality there are three layers as explained.  So during setup in boundary condition how these three layers can be presented using figure above?
How ANSYS can assist me on that case
