Cory Blue
Hello, thank you for the reply, here's the results of the ping from our VLAN to the licensing server:
Pinging undcemlicensing02.und.edu [134.129.182.198] with 32 bytes of data:
Reply from 134.129.182.198: bytes=32 time=3ms TTL=123
Ping statistics for 134.129.182.198:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 3ms, Maximum = 3ms, Average = 3ms
I'm right on campus, no VPN. We are on a separate network than the licensing server, but ports 1055,1056,2325, and 2326 are open between our network and the licensing server. I've connected to the same network as the licensing server via VPN and still wasn't able to launch Workbench correctly. Here's the ping results when connected to the same network as the licensing server:
Pinging undcemlicensing02.und.edu [172.16.182.198] with 32 bytes of data:
Reply from 172.16.182.198: bytes=32 time=3ms TTL=127
Reply from 172.16.182.198: bytes=32 time=2ms TTL=127
Ping statistics for 172.16.182.198:
    Minimum = 2ms, Maximum = 3ms, Average = 2ms
