June 15, 2023 at 2:47 pm
In the geometry is the mount quad for the propeller and below are the dimensions of the mount quad (Diameter propeller = 13 mm). I'm not sure about the contact used for it.
I'm expecting the deflection to be more than 1 mm as 0.2 mm deformation is not realistic for me. 5 mm deformation should be fine (I can also consider changing the material for the propeller).
The mount quad will be screw together with its pair to hold the pylon inside. Below are the backward view of the model.
Graphics are from SolidWorks and Ansys Mechanical files.
Sorry for any inconvenience, I'm new to Ansys Workbench. Thank you.
