June 15, 2023 at 3:28 pm
It seems to work, Workbench 2023R1 loads with no errors, but it takes about 5-7 minutes to load into Workbench when I first open it, is that normal?
The only other problem is when I open the license settings on the client to check the license, I still get this:
Do you know why it would be able to check a license out for a program but I still get that error?
When I was looking at ansyslmd.ini, I noticed the ports are different between the server and the workstation. The server names are also different, but both names point to the same server.
This is on the server:
This is the workstation:
And this is the license:
Should the ansysli_server port be 1056 on the workstation too?
