June 15, 2023 at 6:46 pm
I read, thank you what I need.
BUT I can't add that kind of stuff to Dyna ACT WB.
1. I tried to add a MAT_JOHNSON-HOLMQUIST_CONCRETE snippet and PART card to link the rock to be drilled to the material, but the workbench gives me errors:
Then I decided to add a section map, it didn't help either:
How to add material snippet to Dyna ACT WB?
I have a rigid drill. Rock / blank - sph - I want to assign the material to it through the map:
2. Then I decided to add material to DYNE Prepost. And the calculation did not work again, the following error appears:
But with a simple plastic material he thinks
