Sampat Kumar
Hi Sam,
I have attached some tutorial links for the spherical joint that might be helpful to you.
https://www.youtube.com/watch?v=Kbklvc9Psss&t=585s
https://www.youtube.com/watch?v=kkYLar2etDg&t=1096s
You can also follow the Ansys help document for a detailed explanation of the spherical joint.
Joint Types (ansys.com)
The following forum thread is somehow related to the spherical joint, which is why it's attached here.
https://forum.ansys.com/forums/topic/how-can-i-apply-friction-on-spherical-joints-in-rigid-dynamics/
If these attached documents don't help you, then you can also explain the problem in detail.
Sampat
