Hi Ayeon Hwang,
Will you please explain the question in a little bit of detail? As I can see, the inner geometry is separated from the outer geometry in the first images. Are you expecting any radial contraction of the inner part of the geometry? Are you expecting the inner geometry to move opposite the movement in the attached image? It all depends on the boundary condition that you have applied.
Sampat
