Hi
Not sure perhaps something is due to the gemoetry import after the top. opt.
Can you show a bit more on the pre tension object and perhaps forum users might be able to give some feedback - also as a workaround can you remove the 3D bolts and use beam connections with pretension.
All the best
Erik
