June 19, 2023 at 9:09 am
Hey,
here are more pictures. The problem is, after the topology optimization, I'm not able to apply the multizone meshing to the pins(Bolts) anymore although I declared all the regions touching it and around it as exclusion regions. Maybe therefore the pretension will not be applied, I just can select volumes and not any faces for the pretension feature. Also, after the topology optimization, I applied a patch independent mesh on the optimized beam as the automatic Validation feature did not recognize/mesh the whole beam directly. What can I change/improve?
Thanks,
Patrick
