multi-phase model to use the momentum exchange between the phases is also dependent upon the type of mixture being modeled. owing to the E-E model we can use the heat and mass transfer phenomena between the two-phase fluid and solid. moisture being removing the solid and liquid is transport in the form of vapour from the air.
