Dan Dv
Yes, if you are full Ansys customer, please open a support case so we can take a closer look. If not, we can try and give some more general advice here. First off, I don't see any finesim results, just Ansys Circuit waveforms. But I am also curious what IBIS models you are using here. I really have not seen much in the way of traditional IBIS models being used for MIPI c-phy as IBIS was never really intended to produce the 3 level output signaling that s-phy requires.
