June 19, 2023 at 7:10 pm
I used the sandstone material from the WB base with More-Columbus. But it also doesn't wobble.
I found my mistake: the snippet-material needs to be inserted into the geometry part.
But why doesn't the stuff work in LS-Dyna prepost (not WB)?
And in the Workbench, an error will appear on "_TITLE" in the title of the material.
After failing the sandstone and concrete materials from the WB base with More-Columbus, I decided to try the Johnson-Holmquist material.
