Sampat Kumar
Hi Mario,
Thanks for the information. This is difficult to understand why you are facing the issue with one fluid body without a file. Ansys employees are not allowed to handle any external files or link. I recommend some following points that you can verify.
1. Please use the volume extraction method to make the fluid body.
2. There might be a chance that there would be line contact between the two parts; that’s why you are not able to use the cut operations in this geometry. I would recommend that you try to move one body slightly so that they can interact with each other, and then perform the cut operation.
Please check and let me know.
Sampat
