Sampat Kumar
Hi Javat,
I would suggest verifying the following points that might be the reasons for it:
1. The remote displacement is visible because you are providing for 1 revolution. since the time duration is very less for the rotational velocity that's why you are not able to see the movement of the drill in the true scale. Either you see the result on the large scale instead of the true scale, or you can apply the probe to the stress or deformations to verify the drill rotation.
2. You can also drag and drop the joint in the solution to verify the rotation of the drill.
Sampat
