June 20, 2023 at 9:13 am
Thank you for answering my question. After simulating inviscid flow I am still geting higher results than analitical in terms on pressure difference and mass flow rate. Is there any other factor I should take into account?
Also, I would still like to use data from viscous turbulent flow simulation and compare it to analitical results, but I don't really know how to explain what are all the factors that make simulation results different that theoretical.
Thank you for the help, I really appreciate it.
