June 20, 2023 at 2:20 pm
You can right click on error message and see if it has an option "show probeatic geometry". Not all messages have this option. If the problematic geometry identifies a specific set of faces/edges, you can inspect the failed mesh to determine if there is problem with geometry at this location or if the mesh size is too big for this location and make necessary changes
Consider using a sizing control and reduce mesh size and see if helps
Set check mesh quality to No and see if it generates the mesh. Then check the quality to locates poor quality elements. You can then modify geometry or mesh sizes to improve the quality
