Elizabeth Laughlin
Thank you for the reply Prashanth!
How do I directly set the latent heat? I do not see a place to define the latent heat in the model anywhere. Do I have to make a UDF to define the latent heat?
I tried to set the SSE of the liquid phase to zero and kept the SSE of the vapor phase as the value defined by the Fluent Material Library (a negative value), and I got the latent heat error again.
