Thank you very much for your answer.
I use shell elements with the formulation ELFORM 16.
Thereby I use a SHELL NIP of 3.
As material model I use MAT_107 with the appropriate error parameters of Cockcroft-Latham.
Can it be that only the outer elements that are created based on the NIP command are deleted and not the nodes?
