Paco Sheeran
I see, when you mean the operating density, are you referring to the density of the water/ice? I have set that to both a constant value for water and a polynomial that changes with temperature and both have yielded the same bad result with both. Is that density to be found somewhere else or am I thinking about the density of this phase-changing material wrong?
Also, if I am understanding you correctly, I need an outflow on the top of the ice mesh so that fluid may exit?
Thank you
