FREE STUDENT SOFTWARE Login
  • Community
  • Learning
  • Support
  • Educator
  • Market
  • Career
  • Maker
  • Enable
  • Learning Forum
  • Feed
  • My Posts
  • Help
June 21, 2023 at 3:46 pm
Akshay Maniyar
Hi Gary,
Please check the below knowledge material on the error message. It might help you to resolve the issue.
https://ansyskm.ansys.com/forums/topic/what-is-the-cause-of-the-following-ansys-mechanical-error-the-normal-of-target-element-19817570-is-not-consistent-with-the-normal-of-target-element-19817571-in-real-set-171-please-use-the-2/
Thank you,
Akshay Maniyar
Akshay Maniyar
Cancel Save Reply as Draft Publish
Avatar
Akshay Maniyar
Add Tags
Cancel Save Draft Publish
Proceed
