If the density changes you'll need somewhere for the extra material to go, or come from. A small pressure outlet should be sufficient. However, that may not be the solution.
Operating density is a value the solver uses to anchor some of the equations and calculate terms for hydrostatic pressure: it's covered in the manual. It shouldn't do much here.
