VJ
Hello Gerhard,
If you have strict firewall between the server and workstations, that is when you will be required to fix the vendor port to a static tcp value. Otherwise, it will randomly use a port that is available. It is not recommended to stop the license manager while simulations are running. I'd recommend waiting for the simulation to finish before you do anything with the license server.
