June 22, 2023 at 6:22 am
Hello
To troubleshoot the issue of ANSYS Mechanical not running from Workbench with Static Structural, follow these steps:
- Check the license and ensure it is valid and configured correctly.
- Verify compatibility between ANSYS Mechanical and Workbench versions.
- Load the Mechanical module properly in Workbench.
- Review the model setup in Static Structural to ensure accurate boundary conditions, loads, and constraints.
- Verify solve process settings in Mechanical, including solution settings and convergence criteria.
- Pay attention to any error messages for clues on the problem.
- Consider updating ANSYS software to the latest version.
- Seek support from ANSYS or the user community if the issue persists. Hope it helps you.
