Could you provide a more detailed description of your problem? From my understanding you should check the connections between line bodies and joints and the corresponding connection between joints and solid bodies.
I assume you are dealing with something like that. If yes, you can take this course Bolt Modeling Connections as Beam Elements | Ansys Courses.
