Mateusz Sandrzyk
Hi Saurabh,
Thank you for the response. I contacted with my university IT department and we managed to fix the problem :) Regarding the model, I managed to make it using midsurface function as you have mentioned before. I also thought that for the very first model, an assumption can be made that the base and surface of the board are perfectly rigid. In that case, a joint (joint/remote support/cylindrical support anchored on the edge of the hole) should be placed in the model instead of a pin. In the subsequent model, the base of the connection can be introduced as compliant (also modeled as a shell or as a frame with beams).
What do you think about this idea? Thank you for the help!
Mateusz
