"complex systems...." is for phase distribution is not spherical and no analytical expression then you will need Zemax for help. You only need to extract the wavefront infomation, the phase distribution from Zemax.
"phase_map_from_ZOS_R100um" is the target phase_map. You can use whatever software to create it and save it in .mat:
