June 26, 2023 at 2:31 pm
Hello Marcos,
The choice between using frictionless contact or shared topology for modeling contacts in Ansys depends on the specific requirements and characteristics of your analysis.
Frictionless contact allows sliding but no separation.
Shared Topology occurs when bodies are grouped into multibody parts. It allows for a continuous mesh across common regions where bodies touch, instead of having to define Contact Regions. It is often, but not always, more desirable for the analysis to have a continuous mesh across the parts than to use contact.
As you correctly mentioned, shared topology has a bonded behavior and therefore you should choose depending on the behavior you expect ( whether it is bonded or it is expected to see sliding)
