External Data will only show a preview and not all rows from the text file
In Mechanical, you can turn on the display source points and see if the imported points and the mesh are at the same location. If the imported data is in a different location, mapping will not be complete.
Your sample data only shows X coordinate. Include Y and Z coordinate values and see if that helps
