Mallikarjuna Koppanati
Thanks for the response.
One doubt on the same,
First column indicates visibility of the component in UI,
1) if i give “x” for a particular component,
is it just not shown in the view (or) it won’t be considered for simulation also (or) is it permenently deleting the object like (edit->delete option).
2) I don’t want to consider some of the diodes also for simulation, which are not shown in this “Circuit element properties” menu. Is there any option to deactivate diodes/IC’s from simulation.
Regarding documention.
I have seen mention of ∂/∂f  section 5.38(page 214) in Siwave help pdf as
I have not seen much explanation on what is meant by “Activate/Deactivate” or "visibility(1st column)" on this particular “Circuit element parameters” sheet.
I want to mention it, because i want to make sure i am seeing correct doc for reference.
Please correct me if i am not seeing correct doc.
