You are right that currently you can use (1-Rp-Tp).
Please note that the volume integration method is less accurate since it involves more data calculation. If you are not calcualting the spatial-absorption distribution, using (1-Rp-Tp) should be sufificient.
Improvement for RCWA outputs is under the way.
