June 28, 2023 at 4:54 am
Hello
Both classic Icepak and AEDT Icepak use multiple cores for post-processing and data collation, follow these steps:
- Enable multi-core processing in the software settings.
- Increase solution parallelism by adjusting the settings for how many cores or parallel tasks to use.
- Check that the software is set to use multiple cores for post-processing and data collation.
- Consider using a batch mode or scripting to automate tasks and take advantage of parallel processing.
- Make sure your computer has enough memory (RAM) and fast storage to handle the workload.
- If you need more help, consult the software documentation or contact the support team.
By following these steps, you can optimize the use of multiple cores and improve performance during post-processing and data collation in both classic Icepak and AEDT Icepak.
Thank you.
