Chinmay T
In this case, you need two radiating elements situated in far field distances (the faces of both the radiating elements should be opposite to each other). Then measure the S21 with air in between two radiating elements and then insert the test sample (wafer) and compare the S21 parameters for both cases.
Thank you,
Chinmay
