Are you modeling composite laminate. Typically 'layer' definition is used to define the various layers of a composite structures. So you could have a 4 mm thick element (in your case) but with section definition you can define for example, 3 layers. Each layer can use a different material, layer orientation and thickness but together the 3 layers will add up to 4 mm thickness.
