Could you use RMxprt to create similar model to compare winding sequence and pattern, and us external circuit? The key is the excitation should follow rotor position to provide power because PM motor is synchronous machine. BLDC RMxprt model would generate Maxwell model with external circuit, that can perform this drive. Please check them.
HDLI
