Essence
You also need to use "Extrude Mesh" from Edit Mesh tab. Choose Elements and select all. Extrude by rotation for 2D axisymmetric cases and choose X axis and origin.
Angle per layer: ___ degrees
Number of layers: ___
Merge degenerated elements
Delete original elements
No uncovered faces after delete
Please fill in the blanks according to your application.
