Thanks Rob, I was curious as I came across a source that stated that when making use of the sliding mesh you can't disable the flow field as it necessary for each time step when solving for mixing time. I was assuming that something similar would be true when solving for volume fraction and bubble size distribution as the flow field will be unsteady.
