Hello azhari,
Did you try resetting app data? Which version are you using? Can you follow below instructions.
For example if you have 23R1 installed:
- Go to the Start Menu and open %temp% folder. Search for ‘.ansys’ folder and rename it to ‘.ansys.old’
- Type %appdata% in the address bar.
- Locate the Ansys folder --> select version (V231) and rename it to V231.old
- Then launch the application.
Nanda.
