I suspect that's because you're updating the rotor position rather than using a reference frame (source term) to force the motion. Hence turning the rotor off too!  Any time you turn things on/off to speed up a calculation there are other factors you need to consider: a high proportion of the commercial support I handle is model or "short cut" related.
