June 29, 2023 at 9:58 am
Dear Irina,
Thank you for your reply.
Can you please recommend to me why I have to use gridless, I know that the IEEE follows the standards which are used as a standard for the compliance of the SAR value.
Please see the attached screenshot:
- I have already inserted the density of the material using ITIS database.
- I am using 10 grams of tissues for averaging the over 10 grams mass of the tissues (SAR_10g).
- I am using a voxel size of 1mm, but the resolution of the human body model is 2mm.
Please explain to me why I have to move to Gridless as it does not follow IEEE standards for averaging the SAR values. Secondly, does the voxel size I am using 1mm voxel size for averaging with the 2mm resolution of the model is correct? Thank you
