June 29, 2023 at 4:14 pm
Hello Users, the following instructions I wrote for my team. I've learnt from the ANSYS support team, thankx :)
Sometimes Medini crashes while opening throwing an error "Resource XYZ already exists".To solve the problem do the following.
-Create a new empty text file named like "dummy.mprx" (change ending from *.txt to *.mprx !!)
-Double click the file. Medini will open.
-Select a template like "Automotive" if requested. Medini will create a new project.
-Medini will show as a result the dummy project plus the already existing resource.
-Delete the project that is already existing from the workspace.
-Close Medini and run the original project.
-You can delete the dummy project as well.
