Hello, I am preparing a bidirectional FSI analysis (Fluent + Mechanical) I got this error package:
Update failed for the Solution component in System Coupling. The coupled update for system Fluent threw an exception. Update Solution Failed
(DP 0) An unknown error occurred during solution. Check the Solver Output on the Solution Information object for possible causes.
(DP 0) A solver failure occurred during the run in the Fluent system
(DP 0) Error when making a remote call to participant Solution 1. Please do not save the project if you would like to recover to the last saved state.
There is absolutely no more explanation in Solution Information. What could it be? I need help, I'm on a tight deadline.
