June 30, 2023 at 4:14 pm
Hi Fraser,
Is the standalone Spaceclaim application opening without any issues? If yes, please try these suggestions and check if the issue is resolved after each suggestion.
- Open Workbench and verify if Tools > Options >Geometry Import >Use SpaceClaim Direct Modeler as External CAD is NOT checked. Also, make sure SpaceClaim Direct Modeler is selected as Preferred geometry editor.
- Open Product & CAD Configuration Manager from START menu as Administartor> Install Required prerequisites. After installing, click on Unconfigure Products and CAD> Select all > Hit Next. After Unconfiguring, click on Configure Products and CAD> Select all and hit Next. Open workbench again.
- Open CAD Configuration Manager from START menu as Administartor > Check Spaceclaim>Hit Next> Configure Selected CAD Interfaces.
- Run this command as administartor in command prompt:
reg add HKEY_CLASSES_ROOT\SpaceClaim.AnsysSCDM.2xx /v Path /t Reg_Sz /d "C:\Program Files\ANSYS Inc\v2xx\SCDM"
