July 1, 2023 at 7:28 am
thanks for replying,
yes, I'm trying to model a composite plate using reinforcing elements, but I can't get it right.
the commands are as follows:
MP,EX,1
MP,NU,1
MP,DENS,1
MP,EX,2
MP,NU,2
MP,DENS,2
ET,1,SOLID185
KEYOPT,1,3,1 !LAYERED SOLID
MAT,1
ESYS,0
SECNUM,1
SECTYPE,1,SHELL
SECDATA,0.001,1,45, ,L1
SECDATA,0.001,1,-45, ,L2
SECDATA,0.001,1,-45, ,L3
SECDATA,0.001,1,45, ,L4
BLOCK,0,0.1,0,0.1,0,0.004 !PLATE WITH 100X100X4 (mm)
ESIZE,0.001
MSHKEY,1
MSHAPE,0
VMESH,ALL
SECTYPE,2,REINF,SMEAR
SECDATA,2,1.97E-11,5.2961e-6,0,0,LAYN,1 !MAT, FIB. DIA., SPACING, KCN, THETA, PATT, LAYER#
SECDATA,2,1.97E-11,5.2961e-6,0,0,LAYN,2
SECDATA,2,1.97E-115.2961e-6,0,0,LAYN,3
SECDATA,2,1.97E-11,5.2961e-6,0,0,LAYN,4
SECCONTROL, ,1, ,
ESEL,ALL
EREINF
when the reinforcing section is defined as "2", (i.e sectype,2,reinf), it gives error: the specified reinforcing section 2 for section 2 is a LAYn pattern with layer number greater than one and must be overlaid with a shell.
if the reinforcing section is defined "1", it gives error: reinforcment No.2 in section 1 for REINF element xxxx specifies a layer number which is greater than the total number of layers defined for the base element 2.
despite, my goal is to use a shell section and a reinforcing section in the same element, what is the best way to do this?
thanks in advance
thanks in advance
