July 3, 2023 at 6:59 pm
OK. I have tested all options. Here's what I can say about the rotation and feed of a rigid drill with deformable bits:
1. Rigid Velocity Angular works, but then it is impossible to set the feed using either VELOCITY or REMOTE DISPLACEMENT.
2. The initial angular velocity works, but then it is impossible to set the feed either with the help of VELOCITY or with the help of REMOTE DISPLACEMENT.
3. If you use only REMOTE DISPLACEMENT to rotate by degrees and feed by move, everything works.
But how do you do both rotation and pitch with velocity? It is important.
You cannot move the die to the drill, it is made of SPH particles.
HELP PLEASE.
