July 5, 2023 at 4:46 pm
The simulation would contain the SRR with a lumped port supplying the signal. There would also be two rare earth magnets that are ring shaped.
The magnets would be creating a static magnetic field that the SRR sits in. From what I've read, you use Maxwell for static fields, but I also have the SRR with the lumped port. Is there a way to have the magnets in HFSS or maybe simulate the static magnetic field in Maxwell and then somehow import that into the HFSS simulation?
